hey guys, here we have a freshly ported and polished RB20 head, with individually seated valves (by hand, in original positions), stock valves cleaned and polished, stock valve springs, retainers and camshafts.
Polished camshaft covers. highly polished intake plenum-exterior, and ported inside, with matched ported intake runners.Standard injectors and fuel rail. Standard exhaust manifold (cleaned), with standard rb20 turbo.
Prices.
complete head minus cam gears $1000
intake plenum,runners and injectors $550 or $480 without injectors
exhaust manifold and turbo $250
I will do the lot for $1500.
located on the far north coast NSW, will deliver at a cost, and will post at buyers expense.
feel free to contact me or call-text 0415910256
cheers
levi & alex
also please excuse the pics, as everything is yet to be cleaned and wrapped up.
thanks
This week only special. will do the lot for $1100 cash.
common guys, surely someone must want a decent quality head. all work carried out properly. this is a better upgrade than exhaust etc,
cheers
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
