hi all,
have up for sale my hks cast low mount external gate manifold.
said above is basically it, um its covered in some kind of high temp coating, and is in practically new condition. fairly rare, i kno i hadnt seen one of this till i had one.
please note, this item is for r33 rb25det, i had slight problems with mounting it to my r32 rb25, changing the position on the turbo made it foul on my chassis rail and strut tower (view relevant pics). actualli when u look at it, its only the actuator that was making the trouble, my plan was to block off the ext gate part and run an internal... anyways depends what turbo u wanna run as to what will fit in what and all that jazz...
THIS IS MADE FOR AN R33 RB25DET, if u wanna try and put in on something else its up to you :(
cost - $600 firm.
history - bought this item early december from a fellow sau member, from my knowledge he never used it, and cant remember where he got it from. my plans were to put it on my r32 rb25, however as stated above, this manifold was designed for an r33 engine bay, in mine there is simply not enough room.
reason for sale - as stated above, didnt suit the application i intended it to. now im in the process of changing to top mount.
location - adelaide (north east).
p/up or delivery - would obviously prefer a local buyer, but if not freight can be arranged at buyers cost.
contact - ben (me) via pm, message here or call or txt me on 0438554500
https://www.sau.com.au/forums/topic/255468-hks-cast-manifold-r33-rb25det/
if someone can confirm it will fit rb20 im interested
the bolt pattern ie manifold-engine is exactly the same for rb20/25.
depends what turbo setup you want to use :)
as you can see my poor choice of trying to use internally gated did not work so well.
if u bolt an externally gated turbo you will have alot more room down stairs than i did.
Edited by theminuz
For the record i've got one of these manifolds fitted to my r34 rb25neo using an old hks t3 turbo. We had to shave the engine mount slightly but it fitted up easy enough. It's a great upgrade
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
