r33 gtst 5 speed in good nick nothing wrong with it at all shifts nice and no slop between gears it was in a stock 94 r33
will post pics if needed but u all no what they look like
$1400 pick up bendigo vic or can post
0424897340 call or sms or pm me here
https://www.sau.com.au/forums/topic/255533-r33-gtst-5-speed-gear-box/
