have a series 2 rb25det head for sale complete with cams,cam gears,ex manifold, and polished or painted rocker covers, does not include inlet manifold head is complete and has not been disassembled has just come off the engine and is in great nick looking for $450 firm in adelaide
https://www.sau.com.au/forums/topic/256328-s2-rb25det-head-complete/
not sure about shipping to the us but yeah got around 89,ooo on the head well i sold the polished covers so price drop 350 for the head absolute bargain come and get it
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
