Well, its time to sell the Skyline after owning it for about 3 years. Car has always treated me good and has never in the 3 years i have owned it given me any significant mechanical problems at all, except for coilpacks and damn car alarms! which has since been changed 3 times and is now all good.
Reason for sale is my partner and i have recently bought a home and we need all the money we can get for the house.
Located in southern suburbs of Adelaide.
Very tuff road/street car, has a lot of presence on the road.
***DETAILS***
- 1993 R32 Skyline (Type-M)
- 134,000 kilometres
- Gunmetal Grey colour
- 2nd owner in AUS
- Mechanically it is in great condition, the gearbox is in perfect condition, no crunching or syncho problems, those who have driven it will agree.
- Handles like its on rails, great turn in and grip, the only down side... you feel every bump in the road (However the coilovers are adjustable and this problem can be rectified if neccesary)
- Currently registered
***MODS***
-Suspension/braking-
- Tanabi sus-tec pro front coilovers (Adjustable height, damper, body etc)
- JIC magic rear coilovers (Adjustable height, damper, body etc)
- Adjustable rose-jointed castor rods (Set to about 8 degree castor)
- Front and Rear whiteline thickened sway bars
- ZENITH Solid alloy rear cradle bushes
- ZENITH Solid alloy steering rack bush
- Large GTR type front strut brace
- R33 Lower control arms for more track and camber (Camber currently set to about -3 degree front)
- Braided brake lines
- Recenlty installed Lucas full-metal brake pads
-Power/driveline-
- Boost controller (Currently set to about 11-12 psi)
- 600x300x75mm Front mount intercooler
- Full 3 inch exhaust with front pipe/dump pipe
- Re-mapped ECU by Sam Cornell
- Larger Walbro fuel pump
- Heavy Duty Daikin clutch (Feels perfect, not rough like a button clutch, and has never slipped)
- Metal 'hot pipe' by Exhaust tech (Metal pipe inside the rubber induction pipe to prevent it collapsing under boost)
- Greddy Blow Off Valve plumbacked into system (legal) and now creates a very nice flutter sound
- Pod Air filter
-Cosmetic-
- GTR body kit, side skirts, wing and front bar etc
- Pumped fiberglass front guards
- Pumped and rolled rear metal guards
- 18 inch G-max dished rims, 8.5" front, 9.5" rear (Unsure of exact offset, but pics speak for them selves)
- Tinted windows
-General-
- 360mm Black NARDI Steering wheel
- HKS pillar mounted boost guage
- C's Short shifter
- White vision H4 XENON headlights
- Cyclops Car Alarm and immobiliser (Keyless entry, central locking etc)
- Some 6" front speakers and 6x9 rears
- Also comes with 25mm bolt on spacers that are on the rear in the photo's below, currently not on the car for legality reasons
I'm sure there is also a lot of stuff i have forgotton, if you have any questions, just ask.
***CURRENT PROBLEMS***
- Crack on drivers side of front bar, toward the ground
- Small crack on passenger side headlight due to small stone flicking up
- Passenger side power window sometimes only works from divers side controls (Passenger cannot always put it up and down from thier side)
- Drivers side floor carpet starting to wear away, can be fixed with floor mats
- Interior air-con vents plastic surround has cracked
***PRICE/CONTACT DETAILS***
- Currently looking for $14,000 or nearest offer, have spent much much more on it.
- PM me, or contact me on
Cheers, Ryan
***PICTURES***
- I have tried to include a lot of photo's to give people a good idea of the car
https://www.sau.com.au/forums/topic/256376-1993-type-m-r32-skyline-14000-ono/
i must admit that is one dam nice 32. one of the better ones in adelaide thats for sure.
hope you get what is deserved as it reflects the right price.
  • 4 weeks later...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
