Hey umm i was contemplating buying a car with this plenum mod, but didn't buy it
Now only recently i have been speaking to this guy who is pretty switched on with flow and porting etc. Who is helping me get my car back on the road.
now when i take my engine out we are going to get the inlet manifold bead blasted, then flow matched and then they machine the hole in the plenum for the TB cos it is actually smaller. he even spoke of making it elliptical shaped something to do with flow to #1 and #6. Then the zorst manifold gets cleaned up inside the runners (die grind) and then bead blasted too (mainly all this does is drops zorst temps and relieve turbo).
Now we have decided to use one of those PWR 'Barrel' Coolers (water to air). Original idea was to rotate comp housing on turbo to face down and have the barrel mounted horizontal beside radiator. on further inspection in the S13 engine bay its gonna take some cool thinking to fit it in this position.
Then i thought why not have a front facing TB and have the barrel behind the bumper?
and in my mind it seems right, but i don't know a great deal about flow or anything but if i got the TB front mounted then had the manifold port matched and bead blasted surely it would work?
let me know otherwise i will stick with the other way and cut the shit outta my engine bay
  • Replies 125
this mod is spot on for rb20/25's although i would mount throttle body directly onto manifold to increase throttle response further.
there will be no lean-out in runners because,
pressure in system is equal whether at compressor outlet, intercooler or inlet runner.
compressed air reacts like liquid/hydraulics therefore if each inlet runner is of equal length and pressure is the same each runner will flow equally.
so the big gains will come from your tuner putting more fuel into the engine earlier, 2m less plumbing adds to a ton of response, reducing heat soak and increasing turbo efficency.
  • 1 year later...
Now there's lateral thinking for you - Interesting concept - How are the results RNS11Z ?? Who made the plenum ?? Looks like good work !
Conceptually, there would be good flow distribution with this type of plenum !
Well done !
Cheers,
Does anyone know what part of the stock rb25 inlet manifold makes it restrictive?
Would extrude honing the lower half and removing the odd shaped bumps in the top half benefit much?
Has anyone used a RIPS plenom yet?
PS: Aiming for 450rwhp in a 1200 kg car running a RB30DET.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
