hi i have for sale
R33 Injectors in fuel rail, $120
they came out of my car, replaced with another second hand set to diagnose a problem but it wasnt the injectors fault, good working condition
R33 Stock turbo fuel pump $50
R33 Stock NA fuel pump $50
R33 Series 2 Coil packs $30- that's how much i paid for another set so im selling mine for this much, this didnt solve the problem either, good working condition
R33 Series 2 NA Ecu- $100
Pictures can be taken for anyone interested
Please Pm me or contact me on 0402365334
pick up is from Dandenong or postage anywhere in Australia
Thanks Albz
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
