Press Release 20/2/2009
Today its has been announced that a 10 year agreement has been reached and signed off by both the Springnats PTY/ LTD and the Rural City of Murray Bridge for the Murray Bridge Autofest to be staged each Australia Day Weekend in Murray Bridge S.A. for the next ten years.
Mr Adams stated that this is a major decision and a huge step forward for our sport/hobby and goes to show the strength of Street Machining is finally having within our communities. Unlike most similar events around Australia Mr Adams has concentrated on having events within a community rather than race tracks and the like, he explains that all of the Springnats and Autofest events are held within each of the Cities visited and thus keeps them well and truly in the public eye where any sport needs to be.
Other Cities that Springnats and Autofest events are held include, Corowa NSW Feb 28th to March 1st 2009, Mount Gambier S.A.Oct 31st to November 1st 2009 and Shepparton Vic. November 27th to 29th 2009. It is hope that similar agreements can also be made at these Cities to continue the longevity of Street Machining and the Modified car industry as a whole.
The Rural City of Murray Bridge Mayor Allan Arbon reiterated the event organiser’s remarks and welcomed the commitment by the event promoters. This has enabled Murray Bridge to establish the weekend on promotional calendars and websites which in turn has boosted the accommodation industry’s long term bookings.
The Dates for the 2010 Murray Bridge Autofest are January 23rd and 24th
END:
For and on behalf of,
Murray Bridge Autofest.
www.springcarnationals.com
[email protected]
https://www.sau.com.au/forums/topic/258115-murray-bridge-secure/
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
