this is a in my 700hp R32 GTR , box is designed for race track and not that suited for road use. im selling as im not ready for track just yet.
sale will be conditional on swap for buyers working GC GTR box plus $10,000.
box will be out of car in the next few days and serviced, will take photos and post them then
thanks
thanks
also has a HKS triple plate clutch with it,
Hey mate
How old is the box,how many kms has it done?
And where are you located?
Thanx Paul
Not sure how old box is , came in car i bought. not too sure how many klms on it either .
(although car has 60,000 kms on it)
Box is in brisbane.
Im putting it in for a service next week , so will take photos of all gears and internals while its apart
How much are these new?
i could be interested as im in the market for a tough box..my trust 6speed dogbox wasn't up to it...
The "sequential " 6 speed is $22,000
It takes a bit to learn how to use one properly , but when the engine its at full tilt slamming the shifter back up the gears and forward down the gears
it is awesome, the box screams like most serious race cars. very tough street addition to your GTR or good for 9 second passes.
this box came out of a very tuff street car , never been raced .
H patteren box's are 6k 0r 7k sequential are push forward to go down gears and pull back to go up, faster change more direct drive.
thanks
Hi I am building a GTR33 track car with a OS giken 5sp. Have not tried a 6sp Sequential yet. My mate who used one advise me that
they are high maintainance item. Interested to have a go.
Alex 0433559972 or PM me
a lot of them have been used in race cars because of there direct drive, strength and speed of gear change. Can you tell me what part of a race car ISNT high maintenance....lol if you want to play with the big boys you have to spend the money i suppose.
luckily this box was used on street, just for high speed passes. so is in good condition.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
