Pss Presents: Tech 9 Tyres Bikini Car Wash And Show'n'shine
Come on down on the 15th of March to the Tech 9 shop to browse some of Perths hottest rides on display as well as some gorgeous women washing you car to the beats of DJ Jordan and DJ Benny T playing live.
Bikes - $10
Cars - $20
4x4's - $25
All cars washed will go into the draw to win a set of 20" rims supplied by Tech 9!
Food and drinks will also be on sale!
Check out our website for more details and the......other poster lol
yeah might cruise down after the sauwa meetup.
when do u think the sauwa meetup will finish coz also on this day is a sq comp at westside car audio
Guys going to be a huge turnout and great prizes to win also great talent,
Wouldnt miss it, So try to get your Bottom's Down and have some fun and make friends with everyone in the Perth car scene.
PSS (Perth Street Scene) is for all makes of cars and bikes. Check them out at perthstreetscene.com.
Not sure if I can make this one, I gotta work ;). Couldn't make the last one cos I was too hungover. I'm not doing to well! :blink:
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
