NISSAN SKYLINE R33 GTS-T
12/94
88,000KM
IMMACULATE INSIDE AND OUT
BLITZ EXHAUST
17 INCH SIMMONS
ADJUSTABLE GAB SUSPENSION
BODY KIT
PIVOT TURBO TIMER
ALPINE CD + STACKER + PIONEER SPLITS
TINTED WINDOWS
3 POINT ALARM WITH REMOTE ENTRY
$18,900 ONO
0418 201 478
https://www.sau.com.au/forums/topic/25903-fs-nissan-r33-skyline-immac-bargain/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
