I'll have to get back to everyone on the RX7 injectors (this includes the people that pm'd me). Basically I'll need to make sure these side feeds are all ok to go in (they're still in the post), and once I confirm that they're all good I'll sell the RX7 injectors. They haven't been run in my car, but they came out of an RB20 and they were fine. They were also flow tested and cleaned last week and they are all good (all flowing pretty much spot on 540cc).
The only reason I decided to get the side feeds was out of convenience (and because the price was right :P). I still haven't bought the wiring connectors for the RX7 injectors (they are $30 for a set of 6 from a wrecker). You'll also need 2 bolts which I don't have to mount it and some washers to space it out a bit.
Anyway as I said I'll get back to everyone on them. I'll have to ask a bit more than $500 though because they owe me a fair bit more than $500 so far including the fuel rail and cleaning and flowtesting (over $650 actually). I'm prepared to lose a bit on them though (for something I've never used, talk about bad investment!), so the asking price will be somewhere between $500 and $650 :)
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
