Mortal unfortunately but IMO GT2860RS every time .
These are difficult to beat for the power outup they were designed for which is probably around 320 + Hp .
If you don't have control of your engines fueling and timing then yeah go for the GT2860R .
Don't want to go too deep but wheel wise a GT2860RS is GT"2530" but with a slightly smaller trim compressor (62 vs 63) but greater exducer tip height .
They also use (were intended to use) the larger of the two turbine housing sizes (0.86 A/R vs 0.64 A/R) .
SR20 people who don't have the means to tune or can't/won't accept that more advanced timing where necessary really wakes up an engine with the larger housing use the smaller housing - which chokes the engine .
The feller that spec'd this turbo (JC) used to work for Garrett in the US and wanted something for his circuit Miata (MX5) and the GT2860RS 0.86 A/R is the production version of what he put together . He needed a turbo for his BP18 that would be responsive without being restrictive on the exhaust side and that is what he got .
I had possibly the first one sold in Aust and used it on a street FJ20ET which worked really well .
These are not a numbers turbo for bragging rights but they make an excellent torque in the sort of rev range most 2L engines are driven in .
There was an article in the June 2003 Sport Compact Car - Project Nissan Silvia Part II Behold the Potato .
I'm sure if you search you'll find that one and it has most of the turbos details and pics , and how it was fitted to a JDM SR20DET in a USDM S13 .
Hope this helps , cheers A .
https://www.sau.com.au/forums/topic/259196-gt2860rgt2860rs-and-sr20dets/
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
