Hi everyone,
After taking my car out on the skid pan yesterday i noticed my car would occasionally lose power and sound like it was farting.. it's doing it all the time now and i'm pretty sure i'm only running on 4 or 5 cylinders.
My first guess of course is Coilpacks.. I've had a missfire under boost problem before (which turned out to be the CAS), but when i had the previous problem i araldited my coils because i heard it was a good way to fix leaking coils (as it's a good insulator).
My spark plugs are NGK iridiums gapped to 0.9mm and they've done under 15,000k's.
My oxygen sensor in the exhaust isn't reading overly lean or rich that i've noticed...
So my question is. How do i diagnose if it is the coils (or something else for that matter)?
https://www.sau.com.au/forums/topic/259270-running-on-5-cylinders/
while your engine is running, disconnect the plug to the coilpack. if the rpm drops or the car stalls then that means that the cylinder is firing, if there is no change in rpm then that means the cylinder is not firing. put the plug back on the coilpack and repeat the procedure for the other 5 coilpacks.
once you have figured out if one (or more) of your cylinders is not firing, swap the coilpack from a cylinder that wasn't firing with the coilpack from a cylinder that was firing properly. if the misfire moves to the other cylinder then you now know that the coilpack is faulty. if the misfire stays on the same cylinder regardless of which coilpack is swapped in, then you will need to start looking else where: spark plugs first because they are easy to check, then check wiring to the ignitor module for continuity, check if injectors are firing, compression test etc
hey mate,
i had a problem with my 6th cylinder not firing, and the coilpack disconnect and swap is the go. this will definaetly show up wether or not the cylinders are firing, but the coilpacks still might not be the problem.
you can put a long screw driver up to each injector, and put your ear to that, and you should be able to hear the injectors actuating, by way of a clicking sound. otherwise you can use a multimeter to see wether or not they are pulsing, by way of the voltage pulsing.
compression test is next.
i ended up trying an igniter pack and coil loom from another car, just to rule that out, but a check for continuity with a multimeter should be fine.
in the end my problem was the inlet manifold gaskets, and them being blown out. i checked this by spraying some startya bastard near the affected cylinders inlet tract, and the idle picked up and smoothed out for a second.
cost me 40 bucks i think for new gaskets, from nissan, and a couple of hours work.
hope this helps, Rowdy.
ooo... that's interesting because i can hear a strange "hwoo" noise as it idles, so a blown gasket is definitely a possibility :cheers:
ha ha id like to hear you make that noise in real life :(
another symptom of my cylinder not firing was the engine always 'hunting' at idle. when i fixed it, it smoothed out a lot. this made a funny noise...
let us know how you go
ciao, Rowdy.
I had an issue with my 5th cylinder. Replaced Spark Plugs and Coilpacks and it was still there, turned out to be my igniter module failing, i thought i was weird cause it was affecting just 1 cylinder, but it solved my problem.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
