ALL PARTS LOCATED IN MELBOURNE IN HILLSIDE. Please excuse all the dust in the piks lol they have been sitting in our garage for a very long time haha
Ferah - 0431521947
R33 GTR Rear Spoiler - $150
R33 M-Sports Rear Bar - $150
After Market side skirts (pretty sure they are M-sports too, but unsure) - $150
Jun GTR style Rear Pods - $150
Factory Gtst rear Pods - $100
Left and Right Guards - $200
Factory Gtst Side skirts - $150
R33 passanger door with window - $150
Factory Rear Bar - $60
R33 series 2 front bar, missing fog lights - $60
R33 rear tail lights - $160
Ferah - 0431521947
https://www.sau.com.au/forums/topic/259516-r33-parts/
Hi, Ive got a set of Gtr r33 sidekskirts, but they do not fit my gts if anyone out is keen on swapping a set of gtr side skirts for a set of gtst or gts or aftermakert side skirts that can fit a gts or gtst that would be awsome.
thankx.
https://www.sau.com.au/forums/topic/259516-r33-parts/#findComment-4462196
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
