Hey guys, i had enough of my car and need your help please...pleasee!
(sorry for starting a new thread but i had to, my car pissed me off so much last night)
I bought a Skyline gts-t r33 ser II about 3 months ago and am not that familiar with turbo cars so i thought id ask some of you guys that have had one for a while, so all help is really aappreciated.
Mods on it:
Cat back exaust-(getting rest delivered soon i hope, waiting)
K&N Filter
Tubotech manual boost controller set to 11psi
Apexi cooler
story is: i used to have problems with misfiring until i gapped my plugs to .65mm. The car did start to run better but at times, like last night, car would misfire, cut out totally as if ive briefly let go of accelerator all together and have flat spots all over. car would hit full boost straight away but wouldnt pull, and i would feel it pull propely from maybe 4000 to 4500rpm, and it would go flat again and pull hard around 6500 to 7000rpm.
I dont want to waste money on unnecessary mods but whatever i need to buy i will. Im not going for huge power just decent.
Problem? Im not sure what i should upgrade (apart from front+dump pipe) that could help me overcome this problem. Most of the times when im by my self, car runs not too bad, but with a bit of load, forget it.
Solution-Can you guys suggest what you think could be and what would be the best was to fix it and also what upgrades i need.
Please only reply if you want to help. Really appreciated.
Edited by adis
https://www.sau.com.au/forums/topic/260102-need-help-plz-r33-ser-ii/
Plugs @ .65 = coil packs.
For your mods you should be able to run 1.0 on the plugs without a problem.
Also sounds like the stock ECU having a fit.
Back the boost off to 9psi (once you fix the coil packs) and i bet all problems go away
standard stuff really
UPDATE: Okay ran the car on 11psi and it seemed fine again. So my biggest issues come when i have load in the car-2 mates. Happend before and last night it happend again. Im going mechanics wednesday but i want to get some more mods suggestions, much apreciated.
back it off to 7psi even to where the ecu's range is. I'd reccomend getting somthing that u can tune/get tuned, even if u get an apexi afc/safc, power fc, nistune. something like that
mine was weird before i got my power fc. Upped the boost to 12psi and it hit 4500 and just stuttered, threw spitfires at it with .8mm plugs, still did it. Backed the boost off to abot 8 and it went fine
id say itll be ecu related.... but may just be ur coilpacks
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
