Brake Rotor, $30, it has machined, 3 times machined left, $30
Roger Speaker, $120 very top sound, Drop to $100
PowerSplirit Power Stable Equipment $30 Drop to $20
Unversal A-Pillar Pod 60mm $20
OEM ignition coil packs with HKS plugs(used) $100 Drop to $80
Great condition for full packs and checked volt already, you can offer for Ignition only
Whiteline Front adjust and Rear adjust swaybars $460 (100%new and still in bag)
Z32 AFM $199 (Same as new and tested in perfect condition)
Hi mate, have pm'd before about seat. Are these coilpacks in 100% working order? ive been having troubles getting a good quality 2nd hand set. Just pm me back :blink: interested in both seat and packs providing they suit.
  • 3 weeks later...
hey mate gimme ur mobiles or home number so i can come get the skirts off ur hands asap and the steering wheels if u got em and also the front bar asap!!!!!!!!!!!!!! or my number is 0416337372 just let me know wot ur texting me about tnx
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
