  • Replies 51
Hey guys, Most of the stuff is already gone... so this is just a update of parts i still have at home:
2x Front TANABE SUSTEC DAMPER Shocks and RSR Lowered Springs for R32.
These Shocks are in excellent condition and are Damper adjustable. Only have the front 2 sorry. - $250
2x Front OEM R33 Shocks
In good condition, no leaks or rust - $200
R33 GTSt OEM BOV
perfect condition - $30
R32/33 GTR OEM adjustable strut brace
good condition - $100
R33 Right had side tail light.
No cracks on plastic. Needs clean. Comes with working globes - $60
R33 Stock actuator
Works fine - $30
R33 factory front and Dump pipe - $50
R33 Stock Turbo
Comes with actuator and elbow - has around 1-2mm shaft play in and out. other wise, works fine. - $250
R33 Clutch master cylinder
works 100% comes with original lines. Slave cylinder not included. - $50
Parts that are left are Open to all offers... I want all this stuff gone..
Alright guys.. here is another Update of the parts I still have for sale.
All parts are open to Offers... I just want these remaining items gone...
R33 Stock actuator
Works fine - $30
R33 Stock Turbo
If these remaining items dont sell, I', just going to have to throw them out...
  • 3 weeks later...
---UPDATE OF PARTS STILL AVAILABLE---
R33 Stock actuator
Works fine - $30
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
