Hi guys
I have an r33 Series 1.5 i recently converted it to manual as it was auto. now when it was auto i was running 10PSI fine car ran great now that i have converted it and replaced computer with the manual comp it will only do stock boost 7Psi i modified stock actuator to go staight to 7 psi so no in between. so when ever i try and boost it over the stock boost to like 8 9 or 10 psi its almost like i hit detination or something like fuel cut. it feels like a bad coil pack as i had that problem when i bought the car but fixed that with split fire coil packs
Also i have a stalling problems mainly in reverse revs just drop and don't come back any ideas??
i have PWR front mount
Split fire coil Packs
Iridium Plugs
lighten fly wheel
blah blah and more
car was dynoed and it made 245HP 183kw on stock boost
any ideas guys car runs fine untill you try and boost over stock boost
https://www.sau.com.au/forums/topic/260357-boost-problems/
Sounds like the stock ECU have a fit @ too much load - try searching with "R&R", happens to just about everyone.
As for the stalling, do you have a ATMO BOV? IF so, thats the cause.
If not, you need to clean the AFM, TPS and so on... there are guides in the DIY section
https://www.sau.com.au/forums/topic/260357-boost-problems/#findComment-4467594
was it making this power with the auto? when you do a conversion you up the rwhp by about 30 to 40 hp, i done one a few years back and went from 215 rwhp to 250 rwhp with just the conversion and a FMIC. as with all boost problems and no piggy back or after market ecu, sounds like you have hit R&R. need one of these to fix your problem. dunno about the reversing problem.
https://www.sau.com.au/forums/topic/260357-boost-problems/#findComment-4467601
Car runs extremely rich lots of black smoke Rich and retart how do i clear it?? i have an apexi SAFC will this help??
https://www.sau.com.au/forums/topic/260357-boost-problems/#findComment-4467621
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
