are torrent invites illegal? i seriously didnt know about it....sorry.. but this is what everyone should know that whats happening around us and what sort of world we live in... if you search in youtube watch the 1st episode.....should it interest you...then download the whole from that torrent...
cheers
https://www.sau.com.au/forums/topic/260531-the-arrivals/#findComment-4469846
Not all torrents are illegal my friend :)
I didnt ask for invite to use illegal content, my use of it was undisclosed.
I know the forum rules :P
oooooo i made a friend :D
is free to air TV shows being DL'd legal? :P
honest question
BTW supertorrents+demonoid = :D
https://www.sau.com.au/forums/topic/260531-the-arrivals/#findComment-4470384
It's copyright content so I'd say no but at the end of the day who really cares, if TV networks gave consumers what they wanted we wouldn't go elsewhere hey!
I guess it is like people with TeeVo or who tape things to watch later :D
https://www.sau.com.au/forums/topic/260531-the-arrivals/#findComment-4471099
Oh SNAP! :D
what did i do? :S
but seriously, isn't TeeVo encouraging breeches of copy right laws?
And if people can tape things on TV to watch later, does that mean it is fine to get a HD TV capture dongle thingo to record to your comp?
off topic enough?
https://www.sau.com.au/forums/topic/260531-the-arrivals/#findComment-4471232
a link that a random person has posted on an this internet forum is going to end up in court????once again....wake up to yourself mate
Its the one time it does happen and then everyone says "oh.. wait..."
Its like saying "X" wont happen to you, and then it does.
https://www.sau.com.au/forums/topic/260531-the-arrivals/#findComment-4471362
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
