  • Replies 58
Racing usually starts at 11 but this week may be 10 as gates open at 9am.
I will be calling them up today to confirm all is on track and to re-check these kind of details.
Daz I will be the one [and hopefully only] in a Black 34 with White wheelz :)
That must have been the day I was there too slayer - I just started to get into 1/2 respectable times and then the bloody rain started just as I was about 2 cars off my next run - d'oh.
James: that CANT be YOUR niva, surely? Its way too clean :P
Hopefully its not busy like last time either. Last time we went up the Ford club was there, so it was all kinda busy, then it rained. Its sounding busy, which i don't like the sound of.
If all is good, tomorrow should heat some of the wetness out of the track, and Sunday should be a cracker!
We need a meet point...
Dale: Hahaha - yeah. It was serviced on Wednesday and they washed it. Bastards. I forgot how red it is.
My brother is taking it to Buller on Saturday - so It'll be nice and dirty for Sunday :P
I don't mind meeting up at the Ford factory......
Weather for sunday is still expected to be Fine (20C)...
NismoR34 when you ring up Heathcote maybe ask if thir aware of any other clubs/groups going up as I'd hate to travel all that way only to see 50+ other cars lining up...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
