Ok after searching and having a basic idea of what to and what not to get i would like some definite answers to my questions.
Basically my car will be used for mainly street purposes but i would like to begin attending track days say 5 times a year or so.
And the reason i'm getting new rotors is because my stock ones are done i.e. below minimal thickness.
1. I got plenty of meat in my pads but need new rotors so is it a waste to get slotted rotors and not upgrade the pads well? i intend to get the qfm a1rm pads any reason that i shouldn't?
2. I'm trying to deciding between the RDA slotted rotors from the group buy and the project mu src (not the 2 piece) i know they are priced alot differently but i've read that the RDA's can't handle track days whilst the project mu will handle track days better. So if the RDA's are proven not to be able to handle track day i will be willing to pay extra to go the project mu's
3. Where can i get project mu rotors apart from nengun(i'm in sydney btw)?
4. I'm assuming it would be safe to run slotted rotors at the front and just leaving the rears stock?
thanks for answering my questions. Your help is much appreciated!
Benny
https://www.sau.com.au/forums/topic/261153-brake-pad-and-rotor-choice/
I'm in a similar boat to you. I have already purchased Project mu type NS pads because i heard they were good and am now tossing up on which rotors to buy.
The project mu rotors are at least $590 a pair which is a huge difference between them and rda.
Here's the link to the distributors CLICKY CLICKY
or even check Mus scret but im not sure if they are in sydney
If you intend on doing 5 track days a year (same as what i do), you will need some better brake fluid too. Otherwise you will boil your brake fluid after each hot lap session at the track. I strongly recommend some MOTUL RBF 600. its cheap at around $30 a bottle.
Running slotted discs on the front and standard rears will be fine, as the front brakes take a good pounding at the track.
Also bear in mind that some types of Track Orientated pads will be a bit noisy on the street, squealing and squeaking when coming to a stop. This can drive some people slightly crazy, but others dont seem to mind it.
Good luck and enjoy.
The RDA slotted are great. I run them on the front only and they are just fine. No extra wear so far, and fight fade well. Why spend so much on Project MUs? Oh and yes definately change to Motul RBF600. Well worth it. A brake master cylinder stopper helps too (at least for the feel of the pedal).
I am running stock pads and they are fine on my GTT even on the track.
i had some racebrakes rb74 pads on my gtst and they were great... had 267rwkw. i had dba 4000 series rotors and no dramas... i didnt do any track work.. but my car went up and down the putty rd at least once a month.
I have the RB74 pads on my R33 too, awesome pads for street and track, always pull up. The rear ones are super noisy around town, so i put stock pads in the rear while driving around town. I tried so many different pads in the rear of my car, all were super noisy but stock ones (long story HAHAH). Brake master cylinder stopper is a cheap and easy way to improve pedal feel.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
