wtf... drive through?
faggots the bunch of you. kebabs are to be made by sweaty arab men in the back of a trailer that's parked next to a servo, not out of a drive through, not out of some shop with asian workers, not as part of a franchise and definitely not toasted.
you fags in QLD couldn't organise a root in a brothel when it comes to kebabs.
Fark off back down south then.
And redsuns, your sense of humour is still farken terrible.
I heard AMEC closed down.. so either...
LOL @ sambo no workshop for you guess you have to cup someone elses..... or still..
LOL @ sambo for just being sambo regardless of who you cup :D
So 7:30?
Im so bringing the Mirca. a 747 has more turning circle then this stupid R32
u bought a GTS4?
So 7:30?
Soft Cock!
I have been stimulated bitches. Cheers Krudd for exceptional use of thumbs and pinkies. Appreciate it :)
