as for smithy, f**k man those results are rather depressing.
150+ is what u want, 140's at the lowest. And within like + / - 5
hope you got cash, she'll have to be cracked open... :P
I'd be wanting 160+ actually. Nissan specs say with +/- 14, but yeah 5 or 10 at most would be better.
Was planning to crack it open anyway, as something is definitely farked.
Don't you know R31 drivers never have cash? :( jks
yeeh man, albert rear ended me :(
gaaaaaaaaaay
Totally normal. Only normally its Taz rear ending you...
boot lit, reo, rear bar, reverse lights, rear lights :)
depressing
Your always depressed...emo :(
haha suppose so,
its just gay and such an inconvienance - gota get two quotes today,
any recommendationss ppl?
I would use
"You almost had me? You never had me - you never had your car... Granny shiftin' not double clutchin' like you should. You're lucky that hundred shot of NOS didn't blow the welds on the intake! You almost had me?"
"You know what? This will decimate all... after we put about fifteen grand or more under the hood. If we have to, overnight some parts from Japan."
Two great quotes right there :P
Damn sorry to hear that man.
Might be a bit out of your way but I'll recommend:
G A Wolfe & Co
173 Toombul Rd
Northgate
(07) 3266 3312
He did a FANTASTIC job on my car when i was rear ended by a falcon. He's a just cars authorised repairer too if you are with them.
Well jeez, you should come along to the next meet then!
I think the plan is meeting at the Baskin Robins next Thursday night but keep an eye on this thread for more info. The plan has a week to evolve :P
Anyone wanna meet up for dinner or something? I'll be knocking off from work after 4 and heading straight to Godzilla for a chat with Mark. So... dinner after that anyone?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
