boot floors are part of crumple zone, its meant to crease, you just put it on the rack and pull it straight again. as long as your rails aren't kinked its easy panel beating with parts from a donor cut if the floor's too creased to pull straight.
it'll cost the workshop about 3k to 5k to fix, but obviously they're gonna quote you 8k to make a tidy profit, they're not a charity.
If you don't have a workshop hookup that'll look after you, your best option is find a couple of workshops that'll give you high quotes, enough to write off the car. Just Car's threshold is 70% to 75% of the value of the car. Sometimes you might have to pay em a $100 to make em give you two quotes high enough to get the payout. For them its $100 for typing up a piece of paper and getting the shop down the road to do the same.
Its a good deal Brandon. Tristans car does epic skids :P
I dont think 8k is unreasonable. It would be a fair amount of work to straighten up the car properly and things will always come up which are unexpected. Its probably a 6k job but the guy has given himself a buffer.
PS: GTR + RWD Mode?...
Yea. If it's in my hand it'll be end up like that s15 in the Tokyo Drift movie. Time to knock off work!
not a bad thought funky - ill see what the quotes end up as..
Like OMG ULEH SKIDS?
lol i'm so far from a uleh its not funny!
track skids only haha
You!
I just got a Do Luck Torque Manager with some of krudd's money.
Its fuckin epic. Better than all the other ETS's on the marke. Lets you select what speed you want it to operate at, what torque spilt you want while cornering, and what torque spilt to use while going straight. You want this in your car, along with more low.
use a translator on this site:
http://www.do-luck.com/dtm.html
http://www.do-luck.com/dtm_setting1.html
If you wanna be sneaky, tell em the agreed value of the car is 20k. So when they do the maths they'll think that if they quote around 10k to 12k they'll still get the job.
Nah like epic angle skids.
Oi I hate tomatos Uleh! *kebabslap* (Shan a gif needs to be added of that kebab slap so we can have it as an emote)
You!
Its f**kin epic. Better than all the other ETS's on the marke. Lets you select what speed you want it to operate at, what torque spilt you want while cornering, and what torque spilt to use while going straight. You want this in your car, along with more low.
I have other things that need attention before that is considered. But one will be going in the car eventually :P
Thats genius lol
sif, you're a leb emo.
bahahahahaha. So true
32's are like Dunlop Volleys, if you rip one you just get another one, not try n fix the ripped one :)
lol or you just wear the ripped ones...
good chance to upgrade to a nice HR31 i suppose :laugh:
Upgrade? Does not compute.
Agree. Try to claim everything and get a new/better 1.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
