I got a little bit drunk :)
Pulled a cam cover off, can't see any shims in there so it may not be a NEO head, which would mean I have been ripped off :(
Didnt see anything obviously wrong, and then spotted the stainless exhaust manifold was snapped almost in half. That could account for the funny noise, lack of power and boost, but not the low compression. But I don't have a lot of faith in my compression guage so yeah...
So the plan is to put it back together with a factory manifold and see how it goes. If its still f**ked, I'll take it somewhere for a compression test and leakdown test to work out whats wrong. But hopefully it wont come to that.
Need a new exh gasket and some other misc stuff though, but will hopefully be going back together next weekend. Oh, does anyway know where I can get the right sized copper washers for the banjo bolts? Super cheap/rapeco etc only have imperial ones.
Gonna be spitting chips if this head isn't a NEO one but.
i too will be spitting chips!
that is fcuking shit martin!
called up just cars today - cant get my quotes inspected til tuesday next week..
so no car for 2-3 weeks im guessing :|
seems the pushie is going to be used and abused lol
I'd lend you my backup, but I am using it ATM :P
Looks like it is definitely not a NEO head :). http://www.skylinesaustralia.com/forums/Ea...ad-t269422.html
Wrong number on the side of the head, wrong coil pack mounts. Shoulda researched this s**t more before buying it I suppose.
On the bright side, hopefully it will be all good when back together with factory exhaust manifold now. But the low compression is still a bit of a worry - hopefully its my guage.
Looks like it is definitely not a NEO head :D . http://www.skylinesaustralia.com/forums/Ea...ad-t269422.html
yeeh thats gay dude - hopefully it is just the guage and can be sorted out easily
*fingers crossed
I believe this SR is running a pretty compression all around :D hows yours doing!?
oh shiet :D:P
Too bad the shit bolted to the SR failed more than Johnny McFail at Fail Highschool in Failsville.
I made it out of the spit alive yesterday! I dont think I'll wanna go there again... that place its like a 1 way ticket to defects.
Anyway, anyone knows if the TE37 comes with dish? I saw 1 yesterday thats 19" x 10.5" +22 with massive dish... never seen it before (particularly for funky).
Any farewell car wash for monkey these few days before he gets on the van?
Edited by Brandon
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
