yes tristan is my bitch...
do you know kenmore?
its in the same complex as kenmore woolworths, come along mogil road past indro under the centen hwy bridge keep driving past lexus up the hill when you crest the hill you'll see the golen arches (mikkyD's) turn right and follow the road around to the left and then turn right outside mcdonalds and you'll see nandos. hope that description works.
Thanks for paying me out Tas for not getting outta my car last night, I told you I had a cold and it was freezing, I didn't wanna contaminate you and your friend lol :ninja:
You guys could of sat in my car BUT nooooo, you'd rather stand, hehe...
Nandoes x 2
why the f**k wasnt i called?!
bitch your my bitch!
pfft whatever, so long as we can spoon
Tris: you gotta keep your hands in your pocket.
I think I'll make my way there myself if its at Kenmore shopping centre. Hope I wouldnt be too late...
Shit... Imma give Nandos a miss... Wife practice starts at 7 so I'll only be able to make it after that...
Tris: if you're needing a ride I'll pop by your place and pick you up provided you're not having Nandos...
ps: can someone going please pte me their number. I only got Colin and Tas'. Cheers!
Edited by Brandon
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
