yes wondering what was going on broad minded person.. was installing a hektik cold air intake system on a honda when joo called!
good to see it worked out
oh nismo you looking for 2530 are you?:(
how abt getting what i am gonna get shortly.. disco pot!?
This thursday, be there or be queer like 32_dave.. his still queer and he still goes.
indeed about the queer.
oh shit i meant be there.
picked up another 8 33 rims to add to the drift pile ;) takes myself / astro up to 18rims i think. LOL
i have 3 sets of 4 already plus more at the workshop and also a tyre fitting machine in the other corner theres 2 sets of multi stud 17" and my 16" got me covered :thumbsup:
oh my!
have fun doing it old fashion way ;)
:domokun:
sorry tristan, most of the tyres wernt worth keeping so i poped them off, waiting you to go round to tyre places in bne. 205-215 x 16 x 40-60 asif thats hard to come by, most of you comos / falcons have that size. And for tas, being the lazy man, you wouldnt even no how to take a tyre off the old fasion way, plus it keep you fit. after 8 i was f**ked lol :dry:
Plus there is another 4 tires i gotta mount up, and there is plenty of skids left outa these bad boys !!!
finally finished the motor, shes ready to drop in :)
Got around to mounting up rotors, calipers and pads :)
And purchased a tailshaft, so i can have the yokes swapped when time comes.
oh nismo you looking for 2530 are you?:dry:
Nup, my turbo is fine after inspection and front wheel at least is as big or bigger than a 2530. Whether or not it flows the same/as well is another story.
Fuel pump starts shitting it's self at like 6/7psi and I'm hitting 100% duty cycle *sigh*, fuel pump and reg then more boost to see what it can do
Astro do you have the cash for adjustable things... we're doing 2 orders, a 3rd would make it cheaper.. 3 orders off the top of my head would make rear camber arms like $50USD each
i have cash here for the arms..
msn or pm me the detailsss :dry:
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
