good news tbond and redsuns - soon we'll all ahve our cars running again...
dave?! wens urs ready? :)
thursdays meet will be sexual
ps im soo hungover - my head is killing me :)
dave?! wens urs ready? :D
ps im soo hungover - my head is killing me :D
good to see ur car will be back soon tas. tacio bad luck man, shit happens with such old cars.
my update.
saturday - had to work :P , welder had a family emergency so no go on the guards being installed today, however he test fitted on thursday and they were amazingly good considering he made them remotely.
sunday - got back from driving mrs. / family to the airport. had a go mounting up hydro / dual handbrake setup, looking how best to fit. Had to cut allot out of the centre glove box. Unpicked the handbrake mount off the halfcut, going to weld in so both handbrakes bolt in :) and fitted my water temp sensor, catch can, oil cooler adaptor and afm/bov to motor. Cycled some oil through her as she will be sitting for a bit. Notice in pic i f**ked off the rb25 oil cooler/filter and fitted a rb20 filter adaptor, so could bypass the coolent lines. Now oil soely cooled by my mamoth oil cooler.
Tien Ha suspension tommorrow! looking around! be hardi guess im not sure if i should hunt for super streets and get them revalved and resprung with heavier springs.
anyways astro go ready the events section!
dave and tristan, show us a photo of the oil cooler? i found a whole bunch of trust/ greddy ones.. they vary between 16 and 19 rows but are shit expensive.. thus could go same choice as youj guys..
dave, nice work buddy, its just looking better and better each day!
on wednesday, taking my new front bumper to mates workshop to get it fitted and then get a final quote on the paint job.. fingers crossed
The advantage of the TRUST ones is that they have a thermostat, which allows the oil to get up to temp faster so you are not driving round with cold oil all the time.
I am not sure if those coolers dave and tristan got have a thermostat or not but I am guessing not. And they probably need one, they are f***ing huge
oil coolers don't have thermostats, as I can see. unless its built into the core. Depending on placement of the cooler can assist with temperature. I removed my rb25 standard cooler to also prevent to much cooling. There just your basic justjap jobs. You either pay through the ass for a jap branded cooler or just go mediocre with a generic / Chinese brand and use the brain more and sort problems out urself. September is close approaching... i would of had it in paint by now if the guards had been done 1month ago like they should have. Ignore the temp mounts / pen marks everywhere, took a while to position it all right.
Got home from work today, first unpicked and sanded back the handbrake mounts. And had a play mounting the dual setup.
Major photos:
The idea of the setup complete.
Other Shots:
Its coming along slowly... very :)
Edited by 32_Dave
Thanks Tacio matey for tonight you are a life saver.. pizza's tasted great gf even loved the pasta!
picked up the coilovers.. the fronts are pretty much brand new rofl.. but has different camber tops on gonna remove them later.
tommorrow night! braided lines!
dog c*nt mongrel po po tonight gave me 3 demerit points and $80 for turning right at a dont turn right between 4-6
yeh it was 545 - but still he was a dog
heres a little bit;
"howd u miss the signs buddy"
- "i was running late for work"
"there are 4 signs"
- "i didnt notice im sorry officer"
"mate u shuda noticed the signs"
-"yep well i didnt did i"
"mate how many signs do you need"
f**ker!
ugh
1point for 6months :|
/rant
(awaits mad keyboard warriors - "ur a dog", "ur a hoon", etc etc)
heres a little bit;
"there are 4 signs"
f**ker!
ugh
/rant
i did 12 months on one point, with no speedo. you will be fine
ya hoon dog etc etc :P
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
