that's a long drive for some ice cream. be cool to see another 32 there though
*edit* cos quote thingy played up
Edited by Isola
if only i had access to my on board camera. was at schoolies back in the day.
involved me / mates watchin and 2 drunk chix in there hotel room.
lets just say one squirts...
i confirm!
i was in the shadows watching, touching my bits and giggling deviously to myself every now and then :laugh:
dave i think you need to bring the story up at baskins on thursday!
only have to work 2 days this week :D Uni Monday & Wednesday. Friday is a public holiday and its my Saturday off this week. Work today and Thursday. Epic win lol.
Anyone heading out to Jambo on the weekend? Was thinking of going on Sunday for the finals but not sure yet.
All my uni shit is done for mid semester aswell. got some stupid law mini quizes and then just major assessment which is due in week 10/11ish lol. Lovin it.
tas did you call last nightosomeshit?
it said you left a message on my voicemail, but I cbf checking it. is it drunken ramblings or did you call me while you were touching yourself inappropriately?
Wow... just wow..
sif i call a black man while im touching myself in reality i was actually taking a huge shit while calling :).. just to show you my true feelings lol..unless you was in your baskins and robins suit with yo white sneakers lol ahahahhaah
anyways just joking..
actually called about getting 1st page of google and to fix my shit homeboy..
or ill bust some mango chutney on yo dirty lankan ass :)
need me to have a look josh??
funky and i got some 2nd dodgy ones from mohummed but they was seriously crap.. i reckon just go cheap chinesey 200-250rrp
Not unless you have a replacement for $80 to go in. Siff pay big money for a stock item haha.
Haha, Fins are pretty bad. Been on of "those things" I'll do.
wat u sellin the spitfires for tas?
josh, yeah brah still on for friday. and you can have my strocko 32 radiator, we'll have to test it somehow tho.
Edited by 32_Dave
lol hor hor horrrr
bitches we all going to the baskins meet?
also are they building 2 speed cameras along the centenary freeway between mt cootha exit and indooroopilly exit? fuuufffuuuuu
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
