BUGGA!
Went for the tune today and made 255awkw... I wonder whats the difference between rwkw and awkw... =(
But the car feels soooo much smoother now.
BUGGA!
It’s around a 15% driveline loss.
So say 255awkw + 15% loss (38kw) = 293rwkw = 392rwhp
Which is about right for a standard N1.
@super coach tristan: tried a new grip tonight and got 51 with a strike rate of ~210 :blink:
Also got about 2 dozen stumpings and catches behind the stumps and a few wickets bowling. Good night (y)
To break it down more, rwkw to flywheel kw is roughly x1.33
so, 293rwkw x 1.33 = 389FLYWHEEL KW
Both post's above are rough, everyone has different veiws on loss and conversion rates
Maybe all these while the 300kw I had in mind was rw not aw. But the fact that the car feels lighter/smoother really surprises me. 1st gear used to hit limiter at 60-70km/h now it goes up to 80+. Amazed.
A stock N1 will never make 300awkw, unless the dyno is happy, or you tell the tuner to input 300awkw on the graph lol.
Your car is very healthy and is on par - What else is done to it?
BUGGA!
Wooooo good shit
Ok, the list is as below
1) Trust Ti-R exhaust
2) HKS Front Pipe
3) Apexi Power FC
4) Apexi Boost Controller Kit
Thats all. Everything else is stock. 1.15bar I think (on the pfc hc). Cant get it to hold 1.2bar. No engine mods. Injectors are max at 90%.
Glad to hear the tune is good Brandon, who tuned it for you?
They must have lifted the rev limit a bit :blink:
Gavin Woods @ Autotech. Shit loads of GTRs... oh and 1 Tommy Kaira 32 (dont know real or not)
2) HKS Front Pipe
3) Apexi Power FC
Sort out why it's not holding more boost
- Get a better fuel pump
- Throw in some larger injectors
- Get a good set of cam gears
Spend more time on tuning and you will have a friggin quick car..
Your lack of boost.. They're N1's even 1.2bar is tame... and lack of fuel is why you only got 255awkw. IMHO, with the above and a very good tune you should get up around 280awkw, if you run more than 1.2bar..
If I'm ever gonna get it tuned again, I'll try Matt Spry.
Both Gavin and Matt gave me a good impression when I called comparing to the others.
He reckon its restriction. Or maybe injectors (he's not comfortable running higher than 90%). Or might be the boost controller (I've heard the kit doest hold boost very well after 20psi)
Don’t get me wrong, Gavin knows more about Nissans than most people – however to cut a VERY long story short, I bought a second hand Q45 throttle body from a wrecker, unknown to me at the time the wrecker swapped the TPS unit for a ca18 unit, which meant the car wasn’t tunable… My car was with Gavin for a full day and he couldn’t find what was wrong with it.
I took it to Matty and he found within 5 minutes that the TPS had been swapped over, we put the correct Q45 TPS in and had it tuned…
I know where I will continue to keep going back
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
