lolz. Ok. Will keep that in mind the next time. But I'm pretty happy as it is now but we'll see what happens down the track. Thanks for the info.
[Colin]
[/Colin]
stalker lol :D
Good to hear about the tune Brandon. Pretty decent as Josh said sort out your fuel system and get it to hold some decent boost and you will have a very capable car :D
@super coach tristan: tried a new grip tonight and got 51 with a strike rate of ~210 :)
Also got about 2 dozen stumpings and catches behind the stumps and a few wickets bowling. Good night (y)
very impressed indeed
i didnt realise u were a keeper though - i figured with ur height u were a fast bowler :D
By very good tune I mean someone like Matty Spray..
My rb/S13 with 600rwhp was tuned by Matty.
:D
man I shoulda sampled some of thristan's female friend's muff while I was still in brissy. that brunette with the tig ol bitty's was nice.
which one was that breh?
hmm...
should i get kazama or KTS for suspension arms... hmmm..
triple 9? :)
Dave ya fat slapper, been doing job shit all morning. Gimme a call if you get this, or I'll give you a buzz when i've finished up
epic cupping - rough day nismoh
2x phone interviews this morning, another one tomorrow and had an inperson interview yesterday that went from 2pm - 5pm.
Pretty sure these jokers should just pay me the big bux and not question me.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
