ps: astro check my sig, its locked in bish...
yeh matey just noticed it :)
looks delicious
was at pce this arvo - turbz is looking sexy as feck!
ooohh yeeh boy
Can I dibs on a passenger seat for a mountain run?
Yeah boi, assuming my car is in touge-able condition by the time it happens
Got a quote to fix/modify my shocks today
Cost to replace top thread - :):(:)
Cost to rebuild at same time - free (they have to dissasemble them anyway)
Cost to revalve at same time - not much more, but then i'd really have to do the rears as well so double it :(
Cost to shorten stroke at the same time - :(:(:(:(:( x 50
Car is back together now though with spare shocks and standard strut tops :)
Cost to replace top thread - :):(:(
Cost to shorten stroke at the same time - :(:) x 50
atleast you get a free cupping from dan :)
It's my birthday tomorrow... Someone buy me this...
Stop going to the movies so much and buying video cameras and shit and you could probably afford it :)
P.S. Good taste :)
Hey hey got a progress pic , still a long way to go :( but at least its gettin there.
very very nice :) good things take time
i think some ball cupping is in order...
Thanks for the ride bitch :)
i have had no car for the last couple of days.. my fuel tank was all corroded inside to a point that micro-pieces of rust where being primed into the pump and ended up blocking it..
to get the car back o the road i need a new fuel tank and to clean my pump..
I also decided to get some new parts for it, needa beat some rbs :(
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
    • @Rusty NutshI mate. Do you have a pinout diagram for the na neo auto ecu?
