f**k me josh!
thats jizz - when i have cash for wheels, we'l talk offset :D
Soooooooooooo very very hot. Almost makes me tempted to pull apart my rims to rebuild them for porn fitment, but alas I am a very lazy kid. In past history tells me anything, they'll never go back on my car :/
i bet thats something u'd do
It’s actually pretty common to do a flip/conversion as it’s cheaper than getting custom made lips/barrels made. Pretty common in wheel rebuild threads on a few of the wheel/offset forums I am on.
Yes I post on wheel specific forums
Been wanting to do the same thing:
http://www.skylinesaustralia.com/forums/Ca...-S-t273284.html
Also went and spoke to a shop in Underwood that do a few race cars/drift cars (they did the body work on the Option1 Silver 350z). Without sitting down at working out each cost, they said around $1000 to weld in a pannel.
I have seen roof cuts on ebay for as little as $150. Cut at the pillars, so easy to match and cut, then re weld. People are put off, but I don't know why - People take the roof off cars for SERIOUS roll cage building, it's not different - Your just replacing it with another one.
IMHO if anything putting a sunroof in a non sunroof car makes a car weaker then welding in a non sunroof, roof.
that's a bit better. thought 2k was a bit rough.
do you know if you could fit the non sunroof roof lining once the work was done?
what place in underwood did you see? i work near there, so may pop around and have a chat
wow just went an met my next door naighbor who ive seen playin around in his garrage the past few days, hes got a r31 with a rb26/30, gt3582r, 4" zorts turbo bak ful surge tank setup, big f*k off external gate, the whole f**kin shabang.
Full good dude, Hoping to get it going for powercruize.
Yeap, the more you supply the cheaper it is. I just wanted a sheet welded in with no centre rib (IIRC its only there for two reasons to hold in the roof light and to stop minor roof flex eg: if you lent on the roof in the centre).
If you supplied the centre rib and hood lining and just welded in a plate, apposed to a full roof swap it'll only be around the $1k as well. You can buy the rib new from nissan. I'd also take the sunroof out myself as thats an extra few hours labour you can save. I've had mine out heaps, it's not a hard job.
The shop is in Kenway Dr. Should be building number 6. There is always imports and all kinds of shit there.
**the hood lining on my non sunroof R32's where only ever held in by the side pillar trims, no clips, no glue. There is no reason why a factory liner will not fit**
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
