diff.
boot lid u owe me, your old one wasn't a fair trade, got rust?.
clutch master
oil cap
etc.
im only busting chops.
oh yeh you are cooking :(
sall gooood
fluro rims are old-school, so in with the new
so doing this on my next 32...
oh f**k yes!
imagine getting pulled over and the po po wanting to see under the bonnet
"gladly officer"
hahahhaha
Colin: You may have already seen this and I'm not sure if it's any good to you, or how expensive it'll get. But it might be worth keeping an eye on.
The others I've found are all interstate and would probably cost you the $500 you're setting aside just to truck the mongrel up.
    • I have been wondering if this is as simple as a voltage issue with the battery. Even on a charger, I can’t seem to get it over 11.8V on the terminals.    Unless the alternator has failed as well, that wouldn’t cause it to die in the middle of driving though.
    • I’ll give this a shot next time I’m able to wrench on it.    I was able to get my hands on a Haltech Nexus, so that should help with some of the more bizarre troubleshooting. Make sure the CAS is actually sending signal and will be able to set the proper dwell on the R35 coils.    I’ve checked power/grounds/signals at the CAS, ignitor, and plugs and it was all there. Granted this was static with ignition on, not cranking.    I also plan on swapping out the fuel filter and throwing on a fuel pressure gauge at the rail just to confirm I’m getting the correct pressure at the rail. 43psi if I recall correctly.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
