Erm... whats the exact plan? This week or next? Either way I wouldnt be able to make it to your place by 11. Maybe meet you guys up the mountain.
dear tristan... wish u had my rims ???
they are the secks i will admit - however i have 4 stud fail - so ill go the cheaper option - doriteks :whistling:
f**king love that front offset ;)
and colin im a no bro - uni is ramming me and its starting to bleed
sorry :(
Hurrah, just got call from just cars. Time to get that dent fixed. Dropping it off early tomorrow morning :(
good to hear buddy ;)
get the old girl fixed up - and then manual conversion :whistling:
Looks like I've been outvoted lol. Next week it is lol. Will talk times n stuff next thursday then to suit everybody.
i have 2 here, lol. im sure itll all work out in the end. not sure if i wana sell it thoe, due to nistune / rb25. or i may as-well just get a z32 ecu to retain vct, or whatever the story is. neway ill be around on the we breh.a
an rb20det ecu will not run an rb25, even if it is chipped, unless nistune had worked out how too??
FYI rb25 ecu's are chippable...
Z32 ecu wouldnt work as 300zx motor's arent VCT
hahaha damn them, i reorganised my girls for the weekend and everything... ahh well. I'll RE reorganise it haha. Gold Coast was good :)
http://www.skylinesaustralia.com/forums/Rb...hl=rb25+nistune
as boz said, you can't put a nistune in the r33 board. you can either use a z32 ecu or a r32 ecu. with the r32 you lose the VCT though
is that right or wrong ? might email nistune, what other chips can i use on a 25 ecu ?
NIStune Type 6 Board (TBD)
We are thinknig about doing a board for R33 RB25DE/RB25DET but it involves a fair amount of work, and the parts to interface with the existing 84 pin MCU on this ECU. It is a very difficult board to get started on and requires whole new firmware code to be implemented, whilst supporting customers with our existing product line. I will start drafting schematics once Type 5 has been finished and we have got the knock sensing functionality working.
If you are looking for something to get these going then we suggest either using a HCR32 Skyline or Z32 300ZX ECU with a Type 2 board. See our FAQ topics for more information regarding these ECUs.
Your other option, if you really want to use the R33 ECU is to use an emulator with an expensive third party daughter board (pictured above) available from Sam at
www.drdrift.com.au
you kents should be awake working on cars. im starting on mine in 15 lol epic
Been in work for an hour already lazy carnts
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
