Martin I'll take it.
Also RE bbq if you guys wanna pitch in $5-$10 and I'll go the shops and grab everything. Depends on who's going to come so I know how much stuff to get. Burgers, steak, chicken, kebabs, snags etc.
let us know what the go is.
I’d tag along, but I still don’t have a running car, I got as far as my drive today!! Hell yes!!! Suspected fried injector driver or gremlin power issues to injectors now
Get a lift Josh!
I live in Bulimba. It's like 40minutes from Chapel Hill. Mission for people to come here. Can cat to city if someone is going through that way
fffuuuuuuuuu
Main Entry: me·di·o·cre
Pronunciation: \ˌmē-dē-ˈō-kər\
Function: adjective
Etymology: Middle French, from Latin mediocris, from medius middle + Old Latin ocris stony mountain; akin to Latin acer sharp — more at edge
Date: circa 1586
: of moderate or low quality, value, ability, or performance : ordinary, so-so
Mediocre:
Not good, not bad, but a negative term nonetheless. Often used to describe something that is average, but was expected to be much better.
She was a mediocre student who could have been much better.
Function: adjective
Date: circa 1586
had to push F5...4times jsut to see that? :S :D
Web site looks great tas :D
+1 for "amateur". I don't think there is any negative connotations in that one. Is there such thing as a part-time professional in motorsports anyhow? or any sports?.
You're also missing a word or two in "we reputable" of the second paragraph in About Us
Edited by GTTG
what do people think about products page? not finished but using that click on the brand and should come up from there?
I want to be able to click on the brand and see products, I wouldnt want to be hotlinked to the brands website. Kinda like Greenline, if I wish to buy an ARC product I can see what the suppler can get, not just re directed to ARC's site
http://www.greenline.jp/catalogue/bblist.php?brand=ARC
What nismo said. I hate it when shops do that. I don't care if you can get the whole range I want to be able to browse through that catalogue without having 4 different windows open.
correct.. but it will take some time for me to set that up..
due to the fact there are 11ty billion products currently..
but thats the setup i thought of initially to create the whole.. show i sell for each brand instead of linking to their main site..
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
