I have your mother next to me
Oh snap
when in doubt, cup
follow young olivers example, minus the bowl
Haha hes goin for the double.
edit - check out the look on his face . . . lol
its a look of a man who is determined and prepared for the job at hand.. (or hands as the case is in this situation :happy:)
oh boy i wish i could do photoshop hahahaha :ph34r:
DAMMIT!
READ MY MIND!
ohk if anyone can photoshop - can we pls get a pic of dan and put it on instead of olivers...
and maybe do something about the bowl - LOL!
hahahahhaha
DAMMIT!
READ MY MIND!
hahahahhaha
lol fuuuuuuuuuuuuu
started any work on the beast today? ebc in?
lol at my front yard now, its a spare parts yard :blink:
carbon = delicious
ps thought of the best sticker idea for the dash of epicly sick cars - i'll pm you
3rd gear *jizz*
and yeeh - no need to boost her yet, im still trying to pick up my nuts from stock boost, i just thought u were going to do it so shes ready for when we man up hahahah
BEAST
"bro do the speed limit, its 80km/h, ur going like 70ish"
"err tristan we're doing 120"
"f**k."
rofl... yea its so f**king nice..
should of seen me on the way to work today.. i laugh at people who think they can push in just because im driving it low rpm..
had two cars that pushed in and try to speed off.. when i tried to merge into that lane today..
was curising in 3rd... thought.. hmm.. CHOP CHOP!!! 2nd gear pull
did you do the Tak arm on the window and your head resting on your hand and driving with your left hand only
..you know what i mean
oh we are... we are..
Team Wraith
mauhahahaha :blink:
u should see my rear bar.. :blink: has a rear bar like colins.. epic carbonified
3rd gear *jizz*
BEAST
"f**k."
Pics or :down:
its not all about looks, what about being stealth? :blink:
but you'll soon find out what my number plate is and what my rear lights look like :blink:
with the current situation for danski at the moment astro..
you most likely will have to do it outside his house rofl LOL AHAHAHA
HOHOHO
I cant wait to rape you both in that "car"
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
