You mean to say you aren't going to dazzle me at our wedding?
Vegas :thumbsup:
What work you looking for?
House maid. Or he could clean your pool?
yeh. everything is so farken expensive. 100 people coming to the reception, at a cost of $130 a head. there goes 13k right there. that's more than my farken car.
honey moon, 8k at the moment, without any accomodation paid for yet.
1.8k for the wedding ceremony
2k for dress
then there is shoes, photographer, band and a thousand little details. another 5-6k there
even bigger money pit than owning a skyline
Glad mine didnt cost that much either. Theres a lot you can save on for the wedding if you think about it.
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
