i spy some new names lurking :P
dont be shy...
Maybe they're still on the first page and probably will not see this msg until another 200+ posts? And when they do get here, it will be another 100?? WHORE!
Me? oh im always lurking somewhere......
Oh yer that song is awesome for tractor driving. Might try and find the album "motivational farming music"
Somewhere Central Queensland, 1hr+ from Emerald. The project that was put on hold 2yrs ago finally start after the bloody minister sign the freaking mining lease this Monday. So yea, mobilising to site next month and hopefully I'll be seeing it through from construction to commissioning phase.
Sounds like fun, fkn projects being put on hold and taking longer then should have *shakes fist*
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
