does anyone know what wheels are on this boat? I like 'em... and want a set. Hektik rims bro!
im glad your always being a funny kent. they look like chromes been canned black.
I am impressed dave. lot of work
do mine when you are finished? :D
if you sign the deed over to me :D i wana build another after this one to. ill buy all the right tools this time :geek:
Will do :D - if it's still around, there's a turbo auto s13 in hamilton that looks ok. Hopefully get that and do a manual conversion. If not, I'll try and find a decent s13 that we can throw an RB into. Or who knows? There may be a tidy 180 available, or a 32... time will tell!
I am about to throw a questionable amount of cash at my car so its running again - Make me a stupid offer.
Sick thread Dave. So much work eh. Rescepta.
Well the 31 is home :D Tried to start it, dead battery so jumped it and drove it up and down the street with half the front end missing lol. Box feels pretty nice and it sounds tough as f**k with the straight pipe & no cat lol.
test fitted the guard i bought off ebay and the front end gear I got off Martin/Dan. Will need a bit of work but it looks good. Pictures tomorrow when its light lol. Can't wait to start now :D Won't get started this weekend though because I need to give the GTR a bit of love haha.
if you need any other parts or panels i got a fair bit of them lying around here at home, also if you need bolts i got them from the 2 31's i have wrecked
Panels i'm all set unless I decide to replace the passenger side rear door which has a bit of a ding in it. I reckon it will come out though. Bolts I definitely need for the front guard and fitting the front bar etc.
Ok i'll round up the bolts to hold that stuff together. I got a rear left hand door if you want it, not sure if its straight or whatever but i'll check it out tomorrow if you want it you can take it
Cheers bud. I'll leave the door for now. I reckon I can get the ding out of this one, its not that bad.
Uni work is gay. Looking forward to springbrook later :D
$6,400? whats the matter with that?
Read the description. Just needs blah blah blah. Just needs to cost 3k less.
You must be joking yeah.
gold! :bunny:
wow ohk i take it back, i didnt realise the thing was f**ked - i thought i was just a 32 gtst with average paint
love the run last night colin cheers for that :)
hope i wasnt too slow :$
roll call for the BBQ tommorrow??
whos inners and whos bringing what!?!?!?
i'm a neg for tmr
too slow? where did you guys head? mtns?
