tres accurate
Ok thanks John... so going through carwash is still ok though? Just means getting out and hand drying after?
Or should I do the bucket/car lovers manual clean?
I just had a bottle of coke, from a GLASS BOTTLE
win
QFT :cool:
Oh yeah how's everyone's cars?? Still haven't washed mine, I was told if I wash it I should dry it straight after with a chamoi (spelling?) otherwise the fine dust that's left on my car + water might eat/scrape my paint.
No idea how true that is or if the dude from the post office was just speaking out his ass!
Tis true. Rinse, wash with no overlapping strokes, rinse again, dry with chamois, wax if you have it.
My car was extremely sexy last night but tis dirty again now lol ;)
like they haven't been watching for years... :)
ooooooooo that totally trumps the mcdonalds one. i'm gonna do the same! i'm getting gravy though. kfc sauces are shite.
Yeah Gravy > all. I think I might get 10 nuggets, box of popcorn chicken and 6 crispy strips + a large potato and gravy. maybe some chips as well.
good luck with that
I know what I'm gunna do now :)
quote limit :( tried the other day for an epic "that's what she said"... got denied :(
tres accurate
Yeah quote limit sucks anus.
you talking about the quote button or your shitty macro. for Multi Quote fun you have to hit Add Reply not Fast Reply after you click on all the quotes you want. Class dismissed.
Chocolate Milk FTMFW
:D
Who wants to do lunch?
I'll do lunch :D
I'm definitely getting 40 nuggets for dinner
I raise you another 20. 60 nuggets!
Awesome stuff :cool:
Tastes like Tristian, wait, what.
Josh caught the gay
Car wash will scratch your paint worse than pretty much anything. Apart from the broom shit thing at carlovers. DONT USE THE BROOM.
No. 999 Bitches Cherish it.
where?
Just get a good quality chamois and don't use brushes/scratchy things on your paint
I'll do lunch :cool:
1. sounds good
2. where? i'm more than likely in for lunch, brah. but where are you going?
6 months and still havent cleaned it.
in the 18 months I've had the 'woo I haven't cleaned it. hosed it a couple of times so i could see out the windows, but apart from that, nothing.
load bearing/structural dirt FTMFW!!
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
