Playing the part of Switzerland here so have patience young padawans
In short Taz is far from a tool at the BNR meets most of the people in this thread hang out regularly and the jibes and piss taking is just normal social interaction sh1t that doesn't translate well into text on a forum. Misintepretation is easy over the net but if you were expecting support from people in this thread your mistaken. Taz gives it as good as he gets it so I don't see a problem nor do any of the regulars at the BNR meets.
I know I'm late in on this one - but +1
You insult one of us, you insult all of us. We're not going to stand by and watch our friends get abused due to someone else's misinterpretation of events.
+1. A lot of what Tas says on the forums could make him look like a tool, but then so could a lot of the stuff most of us says. Its very easy to misinterpret over the net. The reality is that Tas is a top bloke, and you can take your unwarranted abuse elsewhere.
Moist lol I haven't used that word in ages. Sounds so dirty :(
Ya sister loves it moist
Shotgun!
Ditto!
I already called it b1tch!
I'll be happy with a back seat run...
I sure am!
Me too!
That's the one. I'm not english I'm Scouse :P
Can't come over today. Not supposed to drive until tomorrow so ahwell. Feeling much better today though. Bruises coming through properly now :P Will probably be at BNR though. I'm not too soft :)
Good form. Mountain run?
Would help lol. Not refering to Terri though...fags.
Nothing faggy about tig old bitties
Edited by Smity42
oh ffs...
look at a quote
dammit john, i guess that means its invalid
@ blah blah blah = posted @ such and such a time on such and such a date etc etc
*kebab slaps*
I know tractors are slow... but TRY and keep up :(
Man just to bring up that malaysian ferrar-ty, I was there last year back before I had my skizza and we were in a taxi from KL to the airport, doing about 90kmh... and this 34 GTR just went FLYING past - I mean absolutely FLYING.
Started talking to the cab driver about it and he said it wouldn't be uncommon if he was doing about 240/250kmh... he told me about some race track that was apparently quite close to where we were, and said there's always imports going up and down that stretch of road, racing each other and being general hoons. Thing is though, cops rarely bug them and the general population (according to the cabbie) LOVES seeing these shenannigans!
*Sigh*
Oh yeah tristo btw you can call me whatever the hell you like, just don't start ACTUALLY calling ME moist hahahaha.
But most of the ladies feel the same way you do around meeeee :(
Not sure about thurs night now, don't have a whole bunch of fuel (I.e. my light's on!) but I'll see if I can avoid eating until payday (saturday) hahahahahaha. I'll keep you guys posted.
oh ffs...
look at a quote
*kebab slaps*
yeh thats obvious
but why fapping and what is/who is barina?
mosi - less excuses, more do
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
