loving the pics :P
soo how was everyones weekendd?
sexual. took a ca out of a mates 180 and threw it in the bin (no, but i wish) and sprayed my rear bar. (looks alright)
i had a pretty boring one, but I was overdue for a quiet weekend anyway :D
gave me time to install Bee*R
Ok whats a Bee*R?
I had the joy of working it was great :3some::D
I don't work AND I don't sleep... 'tis a dangerous mix!
Did you want my job ? You can have it I'm getting over not having any sleep.
Nah, TNT and tequila now thats a dangerous mix.
If I buy a 33.. I want speed stripes like this one!
Thats a sexy ass boat
lol did you find that out the hard way?? :3some:
Ok whats a Bee*R?
Bee*R is a japanese brand. Who make kits, wheels, rev limiters, and other misc parts.
it an aftermarket thingy that lets you adjust your rev limiter
Yes....but unlike factory rev limiters which cut fuel, this one cuts ignition, so it will make you car shoot sick flames when you launch it, but it has a down size....it fouls the plugs, but used in small doses it is fine.
Yeah man those things make the car sound wicked (and shoot mad flames) but heard they not too good for it unless its "fully hecktick" built owe :3some:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
