BDO tickets should be on there way to me now..
Ohhhh. Thats why that explains the long queue along Adelaide Street this morning... Whats BDO anyway. The queue looks ridicules. It starts from somewhere around Boost next to Egames and stretch all the way around the building, along Adelaide Street to LV...
Big Day Out :mrt:
mine faces the opposite direction tbf. I'm doing my part. Well looks like I won't be going to BDO if tickets are gone already lol. Meh only 2 bands I really wanted to see. Anyone know if any bands are going to be doing any other shows while they're here?
There will be a second relese
hai
Well hallooo thar
You are so right!!
*FAP*. Nice Job! Needs bigger pics but...
Yeah true, I had gotten used to distinguishing your posts from brandons, but now danski comes in and I keep thinking he is brandon :mrt:
hai
Oh hai
f**k you all, now colin, brandon AND danskis avatars all look the same
I'm used to colin's and brandon's now. And I don't confuse dans, because his is the best model :mrt:
That's as big as they get sorry :)
I'm used to colin's and brandon's now. And I don't confuse dans, because his is the best model ;)
We just went for a drive so my mrs could take some pics of the car :( Ill change my avatar so no1 get confused anymore :)
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
