lolz!
he must be pretty concerned to actually call the joint
edit- are these for your offset rims?
Just to spite him, I wont even buy them if he cant get his price for half worn tires lol.
Yeh, I just need fronts. They have canvas showing, rears are bald, but okish.. lol.
Oh he went there
I always go there
Settle this on the M1 :P lol
Oh yeah, lets full hektik street race up the M1 uleh. Coz we are full sik kebab street racers cuz
...F*cking street racer F*ckwits...
Tristan's gonna spend 3k on wheels!!!!
noo i was talking about how colin spent 3000 on wheels
you know i like my 180 being a sleeper brandon :P
cmon, someone keep me entertained for half an hour then I can go home
Danski, your car is slow and sh*t, and looks like a HSV
Tristan, you're an emo with a tractor
Tacio, you're a mexican with a tractor, and where the hell have you been anyway?
Dave, get your car done you lazy pr1ck
Tas, stop ricing and get a car on the track
Colin, you're a useless pom
John, bros b4 hoes mang, stop dogging us in this thread
Geoff, stop lurking and say something
Brandon, stop dogging us for bubble tea and sail to baskins instead
Joe, I hear theres a storm brewing tomorrow, anchors away and batten the hatches
Michael, stop looking at the gabnr's 4 penii
Josh, get a real car
Dan_B, you drive a pintara
Harden the f*ck up, Stefan
Anyone I have missed, you are just sh*t
You kidding me right? I've checked BOM and it says clear tomorrow! I'm gonna give the car a full detail with sealant too...
lolz! i dare say that quote is going to keep popping it up - its too priceless
Yea go steal Colin's since he doesnt have any lock nuts.
Well... mine look pretty docile comparing to Colin's mean ass dish if you ask me. Get those bronze LMGT4 and join the family! Hahaha
Oh I put the new Nismo stickers on the rims over the weekend. After the wash tomorrow it'll look brand new!
I guess I might rise to the bait.
Colin, I reckon I've got a mod that'd make your car look awesomely low. bricks.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
