Nah, Just cant get that song out of my head..
Plus if all else failed i'd still be able to help myself out lol
wow. :P
My webcam is finally working. Telstra pulled their finger out so its all good now. No pan or zoom features though which is disapointing. Apparently its illegal..invasion of privacy and all that jazz. So no perving on balconys from the computer. Will have to do it the old fashioned way with a dumpy level on top of the jump lol
Normally I don't like bodykits on 33s but this one is ok. Really aggressive. The stance pretty good as well.
Plus it is armoured so it can survive trips to the stains, dbay, etc
Edited by Smity42
Thats right, I forgot 31s are the only skylines with decent boot space
Ah so they are good for something :)
:O:P
Smaller bodies. you can fit more of them in that way.
Agreed :) you gotta try steer clear of the big ones, they just to hard to get in the trunk :D
cbf quoting.
Thats a huge boot on that thing, Martin. looks almost like a 31 from that perspective.
And its a very sad state of affairs if you can't even help yourself out. :S
Pity about the pan and zoom Colin. might have been good for watching the A1s - among other things. plenty to look at on the balconies at that time of year :P
thats signature worthy :P
hahaah Nooooooooo :D But it is the Truth lol
See how much fun you are becks? You need to stop dogging us and come to baskins
Im not dogging ya's intentionally. I'll come again.. ;)
Dont all act like you guys are the only ones that have a bit of Solo action.. lol
Edited by 83CKS
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
