plol hahaha
so i just finished creating a dream list of parts..
all mainly Mines..
and then i saw.. the price of them rebuilding your engine..
about 23k + freight..
Edited by Redsuns88
23k for a 26?? Sure the mines car is responsive, but i know a better way to get response for that sort of money.....OS Giken RB30 :whistling:
Ive pretty much got my dream list, all i need is an assembled bottom end and decent brakes!
plol hahaha
all mainly Mines..
Depends on what you get for that 23k. If thats for a crate motor all ready to go incl ancillaries(spelling?) then its not too bad.
Giken 30 you pay 23k just for the short block! Whats the specs on yours?
oh and newer suspension, its ok but it looks like its very old
Bilstein Kit from Dan is good :thumbsup:
plol hahaha
all mainly Mines..
Just reread that and saw that word lol. Again it depends on what you get in one of their rebuilds but 23k is f**king exxy.
its got the head too with cams of your choosing it was 26k last time i checked for that, but that was delivered.
General specs are
HKS 2510s that were slightly highflowed upon rebuilding so are rated at about 325hp each instead of 310
Ported Head
Tomei Poncams so whats that 260 somthing degrees and 10mm of lift? somthing like that anyway
Power FC (Want to change that to the new adaptronic super ECU)
Z32 AFMs
Sard 750cc injectors in a Sard fuel rail with a sard FPR and some big intank pump
Trust dumps and front pipes into some random 3.5 inch exhaust
ARC intercooler
Profec B spec 2
Apexi intake piping and pods
NPC Twinplate
Rebuilt Gearbox
Rebuilt 4wd system
Rebuilt drive shafts
19row oil cooler
Oil mods to the head, restrictors drain at the back of the head ect
Baffled sump
Currently being done
Rebuild including:
ACL pistons
Spool rods
and new billett oil pump gears designed by shrek and ranga
external fuel pump and surge tank
I think thats about it
Tis a very nice list :D
omg colin since when do you design stuff? :whistling:
:thumbsup: I don't. Not oil pump gears anyway. That be Shanef :D
i have literally deflated my left nut over this..
and my right one
tomei?
FK this, I wanted to add my even sexier dump pipes but i can only fast reply as the frigging normal buttons dont show up on the f**king computer for some reason! :whistling:
nope work computer, im betting that the image for the button is hosted somwhere that is blocked auotomaticly, lots of threads have no pics on this comp too, but not a notification that its blocked jest a big area of nothing
I feel ya pain, I get heaps of plank spaces on my work pc too :whistling:
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
    • Have you done 10x restarts since it came on?
