Which is why I'm not buying anything until I have a car to put them on. But I can still plan :down:
furry muff.
But you dont wanna be like all the school kids on holidays
"OMG I WANNA BE A FULL HEKTIK DRIFTER I DON'T HAVE A CAR OR A LICENCE YET BUT I LOVE THESE WHEELS WHERE CAN I BUY THEM? I THINK THEY ARE ENKAIS. I HAVE $57 TO SPEND BUT MAYBE I CAN BORROW SOME MONEY FROM MY PARENTS IF THEY ARE A BIT MORE THAN THAT"
:P
Edited by Smity42
I know of some 18xstupidsizeforusing he should buy
You know you want them!!!
I was gonna use flares that I had, but I went with the stockish look.
My gaurds are pretty stockish looking. They are a huge high offset, so they fit okish just pretty much cannot turn as they sheer the rims on the inside and the camber needed is just stupid
The rims themselves sit like an ich out lol when it has no camber
Ah there is a picture...stupid firewall blocking photobucket..
the ones I have I don't have a problem with...no rubbing they just stick out an inch past the guards.
Im too much of a tight bugger to pay for gaurd so high offsets will do me :down:
Indeed. Just counting down till midday, then I am off for lunch at Breakfast Creek and meeting up with the Christmas Party Comittee.
A couple of beers should see me through till knock off time. :down:
I remember we were driving, driving in your car
The speed so fast I felt like I was drunk
City lights lay out before us
And your arm felt nice wrapped 'round my shoulder
Yeah that was a great night :down:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
