sounds like your a pill popper :P
and a weak one while at it :down:
Weak ? ? ?
Hmmm . . . . anyways
edit - sometimes I wounder if your stupid or you just dont speak very good English?
They have to be, seeing they never win the cricket
Hahah same as the kiwis
What did you get Ro?
Not what I got but what I have and not using and wanting to sell actually. It's in bold on page 167 or 168...somewhere.
Morning All!!
Thank God it's FRIDAY! :down:
TFIF ey.....so getting crunked tonight.. Come into work tomorrow with a hangover...then leave at 10 to go get on a plane. Going to bed an ugly flight me thinks.
Quote for proof that Colin is totally in love with the cock
lol
Depends largely on the mood I'm in.
:P RnB ftl
+ 1
Dance is good though, sometimes. Most of the time it's metal etc.
Good one Josh!!
Weak ? ? ?
Tas is still pissed I told him he couldn't fit into my size 30 emo skinnies :devil:
Silly kiwis
yesi spek no good engrish..
lol
i LOLed so hard when i was reading your comment about kiwi haha
hahaha someones abit touchy about being weak
I speak Japanese,
Trust, Mines, HKS
hahaha
lol
Touchy . . . hmmmm or maybe I just dont understand why retards write comments that make no sense ?
Ashes? Not that I care. I would rather put pins in my eyes than watch that shite.
pretty sure we let them have this one
Dam f**kin straight. We let you have Australia you better let us win sometimes...flamin mongrels.
It's a conspiracy
Everythings a conspiracy :devil:
I hate the game with a passion
I think Australian is a shite place to live too
Or maybe you just don't understand it all chappy? :devil:
and feel frustrated that you are being left out
aww its ok chappy im here for you!! *group hugs* even if they do make youtube clips about you
Edited by Redsuns88
Ahh that makes sense then
As is me, am I a spam bot or am I real. Dun dun dun
Spam bot for sure
What kind of useless pom are you?
LET us have it? You dumped us here coz you didn't want us
How bout that moon landing hey? :P
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
